Tex total weight with billet or alum?
I understand that the Tex pressure plate weighs more than stock, so a 18lb billet flywheel is only going to give you a marginal weight advantage. The aluminum flywheel weighs only 8lbs!!! I am trying to find out the total weight of the clutch,pp and flywheel vs stock to make my decision. This is for the 0700 series single disc setup. 8lbs seems way too light but depending on the pp weight it may work just fine. Does anyone know the weight differences between the 3? Thanks for the help.
