rpm drops how much between shifts?
after the hp peaks should you cary the rpm for that much be for you shift again?
6000rpm peak and hold to 7200-7500 till i shift
OR
6000rpm peak and hold to 6700-6800 so it fall right be for the peak?
OR
Originally Posted by TigerWoodsJr
I hope you aren't revving a stock LS1 to 7200.
Basically shift when your power is starting to run out and the band is going down.
-brandon
try this link i think it should work you might have to copy/paste not sure how this computer thing works
file:///C:/Documents%20and%20Settings/jeff/Desktop/gears.htm
OR
OR
