Generation IV Internal Engine - L92??
View Full Version : L92??
what is this motor in? vettes, trucks, or just after market? sorry for being dumb just wondering
03 BUSA
12-24-2006, 08:19 PM
It is in the trucks. I know for sure it is in the Escalades, I am not sure which trucks though. Prolly the GMC and a option in the Silverados, not sure about that though.
Bo185
12-25-2006, 01:54 AM
Currently is only in the 07 Caddy Escalades and the 07 GMC denali truck/suv.
It's not in the silverados yet.
DoesSpeedTurnUon
12-25-2006, 02:08 AM
However, from what i've read, i THINK... the VortexMax, is a 6.0 with L92 heads and the L92 truck intake.
Bo185
12-26-2006, 01:14 AM
The L76 VortecMax is basically a L92 with a 4.00 bore. And maybe a different tune. And it hads DOD on it were as the L92 currently doesn't have DOD.
Bring the Noise
12-28-2006, 12:51 AM
Bo185 the GM L92 based vehicle's do have DOD, its name is actually Active Fuel Management.
The L92 in the GMC Yukon Denali does not have VVT (Cam Phaser) and is only rated to 380hp.
The L92 in the Caddy has VVT and is rated to 408hp.
The Vortec Max in the 07 silverado is the L76.
Ironicly the Chevy Tahoe doesn't offer anything larger then the 5.3L Iron Block, but the TrailBlazer SS comes with the LS2???
The L92 shortblocks that are being built just plug the feeds to the solinoids and use the LS1/LS2/LS7 style lifters.
Now I liked DOD over AFM.
I'm guessing someone in GM's upper management thought having the same designation as the department of defense was a bad idea.
429 Mustang
12-28-2006, 07:44 AM
Then that someone is a dufus, because it's DoD, not DOD. :guns:
Bo185
12-28-2006, 10:00 AM
Bo185 the GM L92 based vehicle's do have DOD, its name is actually Active Fuel Management. So were did you get that information? Web, GM, or a dealer???
From what I have seen and heard the componets are installed in the L92 they just aren't using it yet. They seem to be having problems with the Active Fuel Management (DOD) and the 6L80E trans. working together.
INFO HERE:http://media.gm.com/us/powertrain/en/product_services/2007/07truck.htm
GM Media Online
The L92 in the GMC Yukon Denali does not have VVT (Cam Phaser) and is only rated to 380hp. From what I have read all the L92's have VVT. Any information and sources as to actually what they have or don't have?
The Vortec Max in the 07 silverado is the L76. The L76 vortec max motor has AFM and VVT.
L76 per Chevrolet web site.
Vortec MAX 6.0L V8 engine features:
* Variable Valve Timing (VVT) technology that optimizes combustion, enhances low-end torque and high-end power, promotes fuel efficiency, and helps lower emissions
Ironicly the Chevy Tahoe doesn't offer anything larger then the 5.3L Iron Block, but the TrailBlazer SS comes with the LS2???. But you can now get the L76 in the 1500 Burbin'. Don't know if they have made them available yet.
Mike454SS
12-28-2006, 12:26 PM
So are L76's and L92's using the same heads and intake?
Bo185
12-28-2006, 03:43 PM
They use the same heads and intake. Don't know about cam
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
