How to port your oil pump
Old 12-25-2006, 01:23 PM
joshluther's Avatar
Default How to port your oil pump
Wasn't there a how to some where? I searched and didn't find it.
Old 12-25-2006, 01:35 PM
The1N_only's Avatar
this is what i did
Old 12-25-2006, 02:01 PM
joshluther's Avatar
Did you shim the spring? What did you use if you did?
Old 12-25-2006, 02:03 PM
The1N_only's Avatar
i went to the hardware store and got some washers that added to .100 and that fit in the little cap. I got a few funny looks as im using a micrometer to measure washer thicknesses lol
Old 12-25-2006, 02:12 PM
Ferocity02's Avatar
To port it just take it apart and clean up in the inlet and the outlet. Use common sense and don't grind anything important.
Old 12-25-2006, 02:14 PM
The1N_only's Avatar
Correct, if your worried about nicking anything use masking tape to cover all the areas you dont want to get touched
Old 12-25-2006, 02:36 PM
joshluther's Avatar
Cool Thanks the pump isn't that old so I couldn't see buying a new one.
Old 12-25-2006, 02:39 PM
The1N_only's Avatar
yeah, just pull it apart and look for any unusual wear
