Conversions & Hybrids - LSX into LT1
View Full Version : LSX into LT1
the_merv
12-25-2006, 11:02 PM
What's up-
This is my idea. I am looking into building up a LSX 6.0l iron block out of a truck. I have a 95 Z28 LT1 OBDI car, LT1 PCM, etc. I can get a LSX PCM, Harness, and build the Engine up.
This is the problem:
I want to find a Harness, or build one that will run the Engine and Transmisson, connect to the PCM, and adapt to the 3 plugs underneath the dash so the guages will work. I know it will be primarily a LSX Harness, but it still has to connect to the dash.
Does anyone know who can do this, or have any wiring diagrams that I can follow to build it?
Would it be easier to get a complete LS1 Dash out of an F-body Car, wire that in and use that?
MyWs62FaST4u
12-26-2006, 02:02 AM
yes, BS3..or a GenVII...I chose that route!
the_merv
12-26-2006, 06:38 AM
Ok.. what are they?
SOMSS
12-26-2006, 08:39 AM
You may want to wait for the new GMPP LSX Iron block to be available. It is the best performance block available for hi performance applications. It can be bored out to 519 cu. in., you will be doing yourself a diservice in not using it.
the_merv
12-29-2006, 07:10 PM
I still have to wire it in.. I can build anything, the wiring is the pain in the ass.
G-Body
12-29-2006, 10:40 PM
I believe that speartech can do this. Last I heard he was still doing custom direct plug in harnesses as long as he had already done a custom direct plug in harness for that car. I would guess that he probably has done a direct plug in harness for a LT1 f-body, but I could be wrong.
You could also do it yourself, I don`t know of any wiring diagrams for a LSx into a LT1 car though, LS1 into a v6 I know of :bang: but I don`t think that would be as much help. If you get full diagrams for the car and the LS1 it wouldn`t be too hard.
You could use the LS1 dash and harness, but for that to be a direct plug in I would think that you would end up changing a lot of wiring in the car.
Tiago
12-29-2006, 10:59 PM
I rewired the 3 connectors on the ls1 harness into the single connector that the 94 car had under the hood. The interior connectors were straight forward for the most part...
there are a few wires on the ls1 harness that are originally going under the hood but need to go back to unnder the dash on a LT car.
FAQ and www.shbox.com is your friend.
the_merv
12-29-2006, 11:06 PM
Shbox has the Diagrams, so does my Haynes Book. You have any notes on what you did? The LT1 car has 3 connections under the Dash.
I can get Pin Diagrams and figure out what they all go to, then go from there I guess.
G-Body
12-29-2006, 11:10 PM
Yep, looks like speartech does offer a plug and play option
http://www.ls1tech.com/forums/showpost.php?p=5839650&postcount=8
the_merv
12-29-2006, 11:24 PM
Cool stuff..just something for down the road in the future, a built up 6.0 LSX.
-Just called them, and they do offer it for a good price. Looks like a few people are starting to do that now.. :devil:
jfman
12-30-2006, 01:01 PM
I have an ls1 subframe and motor mounts if you need them.
the_merv
12-30-2006, 02:32 PM
You mean the K-Member?
jfman
12-30-2006, 02:43 PM
yes the k member
the_merv
12-30-2006, 07:59 PM
I am looking into the wiring stuff for now. Once that is done, the rest is just building..
firebird6786
01-02-2007, 10:40 AM
can you use just LS1 or LS2 motor mounts
