Dont want to sound stupid but..
I took my car down to my friends shop about a month ago to put my asp underdrive pulley on because he said he had the right puller to get it off. We got the old one off fine and i got a new bolt but he said torqing it down doesnt really matter and we just ran it down with the impact
i have been reading some writeups on putting them on and it says you should really torque them down. WHat should i do it want it done right?
Kleeborp the Moderator™
If you use a new, stock type torque to yield fastener, then you need to follow a certain procedure (not sure how many degrees more you have to go though off the top of my head), and if you use an ARP crank bolt, I think the specs on that are 240 ft-lbs.
However, when I had a buddy install my pulley, he put it on with an impact wrench and was done with it. The pulley is fully seated, and has never wandered off, and that was 20 some-odd thousand miles ago. I'm not too terribly concerned about it either.
ya, and hes not going to pay if it comes loose either, dont listen to idiots who think they know it all and dont want to listen to the customer
a good shop will read the instructions and torque to the specs of the part
Originally Posted by 2001sunsetmetalss
im not worried about it wondering out he hammered on it with a 1/2 impact i was just wondering if over doing it would mess with the crank
1)Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft
2)Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft
3)Crankshaft Balancer Bolt (Final Pass) 140 degrees
