need help with new turbo set-up for 98 ls1
Help with new turbo set-up
recently purchased a 68mm precision turbo with hks w/g air 2 air int. it came with ls1edit loaded on the pcm. i received the cable to connect to laptop, but i did not receive the software disc. the previous owner said all i needed to do was change the c.i.d. on the pcm and it would run. anyone know where i can get the software needed to run this? a little info on the build. 98 ls1 firebird with auto. this turbo made 600+ rwhp with lsx intake and 350 turbo trans. also anyone know what would be the best in-tank fuel pump to run would be. probably stay under 8psi boost because of stock trans and rear, until budget allows upgrade. also anyone know where to purchase a maf extension cable and inlet pipe and filter as mine didn't come with these items any help sure appreciated. thanks in advance.
Get couplers here: http://www.hightempsilicone.com/
My MAF needed to be stretched; I just cut the cable and soldered in new legnths of wire to stretch it out. No problems.
