Security light on..WTF!?!?!
Old 12-26-2006, 06:29 PM
JacobK's Avatar
Default Security light on..WTF!?!?!
Hey guys i just got back from vacation and when i left for vacation the car was fine, so today i get back and start the car and boom, the security light is on..Car started fine and everything but it seems like the light is stuck on..What do i need to do to fix this? or does anyone have any idea on what it can be?
Old 12-26-2006, 07:11 PM
2001NBMZ28's Avatar
First thing I'd do is try cleaning the key/trying a spare if you have one. If that doesn't work might be a VATS issue. Any chance someone tried to start the car with a different key pelet value?
SSpdDmon's Avatar
That's the VATS system (resistor in your key). Check your manual for more information. Connection between the key and the ignition cylinder may be dirty or showing wear.
Old 12-26-2006, 07:40 PM
JacobK's Avatar
i dont have a spare..so i should try cleaning the key? and if that doesnt work buy a new one?
Old 12-27-2006, 03:16 PM
StreetLethal01's Avatar
I have the same issue. I tried cleaning the key and tried the spare set and still the same security light won't turn off. No problems starting.
Old 12-27-2006, 07:21 PM
lsx24's Avatar
I had the same issue and was told my ignition tumblers needed to be replaced, but my light was coming on and preventing the car from being started.
It's definately a key/tumbler issue though...
Old 12-28-2006, 12:01 PM
F-117HWK's Avatar
My car has been doing something similar lately. The difference is my car is completly dead once the security light comes on. I then have to like get out of the car and just wait for a few minutes then try again and it normally works. This has happened around 4 times in the past few months so is the issue possibly the need for a new set of keys?
Thanks,
Jason
Old 03-14-2007, 09:46 AM
SSnakekiller's Avatar
Read my reply #11: https://ls1tech.com/forums/showthrea...highlight=vats
But by now you have probably figured it out.
