PIAA 1100x <<Holy CRAP>> These fog lights are the ISH!
Got these for xmas........holy **** are they bright!!!
I went for a drive tonight and didn't even need the headlights!
here's some pics......
They intalled in about 30 mins, bolted right up to the stock brackets..pretty nice!!!
I just want to say that the right fog light is aimed a little higher on purpose...
I live in the woods and I want the right side of the road lit up in the trees so I can see those damn deer......and I wish I could aim the left one up a lil more, but then I'd be blinding people.......so yes the are not the same height, but that's on purpose.
PIAA 1100 = NO HID
'Bulb Type 12V - Dichroic 55watt=85watt Super White'
I've had a set on my T/A for a couple years now - I regularly drive at dusk without the headights - could drive all nite actually with just the DL's
Good price too - I usually see them for around $179...
BTW, Nice car and even nicer house!
Originally Posted by CULATR
Hey did you use the factory fog light wires to wire them up?? i need to know being as i will prob grab a pair soon .......
All I did was cut the connector for the stock lights off. Then I cut the connectors provided with the fog lights and left some wire to manipulate. I then stripped both the wires on the car, and the wires cut from the install kit. Twisted them together, and put some shrink wrap around it. Works well
Those aren't fog lights. That's why they're so bright. That's definitely a driving light beam pattern. Driving lights function along with your high beams to better illuminate long distances. Fog lights, on the other hand, will have a sharp cutoff that's low to the ground, to better illuminate the ground near the car in bad weather, along with your low beams.
If you use those alongside your low beams, you'll blind the crap out of other drivers. Driving lights should be wired to come on with your high beams, exactly opposite the way the stock fog lights work.
Copy & Paste Moderator
You could also install them without cutting the factory wiring. Here is how I installed aftermarket foglights on my Formula.
http://www.fadingarrow.com/FogLights.htm
I just did do the mod where the fogs stay on with the high beams so that's great.
You can aim them down all you want, but it still won't solve the problem. It's a fundamentally different type of lamp. The beam pattern is long and thin, where a fog light is low and wide. They're awesome lights, but i'd suggest wiring them to work with your high beams only. Oncoming traffic will thank you.
I started feeling bad for people tongiht so I made a low and high setting for them...
Couldn't figure out how to make them come on with highs only.... I know I could prob just splice a wire to the high bulbs, but i didn't wana burn out any fuses or wires......
Any ideas?
Any ideas?
