can hptuners scanner show me how total timing is being derived?
Supercharged V, car is pulling 4-6 degrees at WOT and I cant seem to find the reason why. not getting KR, car must just be being told somewhere for some reason to pull timing for the conditions its under.
if tuners cant do it how bout efilives scanner?
I didn't try burst knock. Ok instead of assuming certain tables are not coming into play I will lock all knock / advance pids and see if it shows me anything.
Moderator
Definitely log every advance and retard adder you can
find in the PID list until you see which ones are nonzero.
Also log your Knock Learn Factor as this can "steal"
timing by pushing you toward the LO table from ping
history, otherwise unbeknownst.
ok folks it's burst knock.
is there a method to this table or since the car is supercharged should I just zero out and let the high/low timing tables take care of things? or is there a "proper" way to do this so it can do it's job even though car is FI now?
Many zero it out and get no real KR. Just drop the values down and monitor for knock logged and audible and go from there.
With forced induction you will be triggering the delta air values real easy. You can also bump up the triggers as an alternative. But Id say dropping the BKR retard values is your best bet. Just make sure you arnt going to create knock by doing so.
