ls6 head swap question
Old 12-27-2006, 12:36 AM
TA1972's Avatar
Question ls6 head swap question
Hi, I am planing to put ls6 heads into my 99 ls1,but I was wondering what type of head gaskets do i need to buy and other parts that goes with this swap. Do i use a ls1 head gasket or ls6? I'm a newbie so please help
Old 12-27-2006, 07:32 AM
2002blackZ's Avatar
The gaskets are the same size for both LS1 and LS6 heads. You can use stock gaskets if you plan on staying NA. Upgrade to a better gasket if you have other plans down the road.
As far as parts and instructions... check out this link.
http://www.ls1howto.com/index.php?article=3
Have fun and take your time... It's not too hard.
Old 12-29-2006, 01:59 AM
KW4life06's Avatar
how good r the ls6 heads over stock?
Old 12-29-2006, 07:45 AM
2002blackZ's Avatar
the overall design is better than the LS1 head, but I would go with a ported head over a set of stock LS6 heads.
check with the board sponsers. most of them have pretty good package deals and can make recommendations on combo's that work well together.
