Just want to double check what codes to remove
Old 12-27-2006, 01:10 AM
Gregg 00SS's Avatar
Default Just want to double check what codes to remove
Just installed True duals, no cats, etc... Are these the proper codes to remove?
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
P0141 HO2S Heater Circuit Bank 1 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
P0161 HO2S Heater Circuit Bank 2 Sensor 2
P0420 Catalyst System Low Efficiency Bank 1
P0430 Catalyst System Low Efficiency Bank 2
Also just installed a 3 channel 9" in my 4 channel car and thus have no ASR or ABS now. I did a search and seems nothing can be done to remove the ABS light other than cover it with tape, how about the ASR light, any codes to remove that? Any other codes I should look to remove with the mods I've recently installed?
Old 12-27-2006, 07:52 AM
brad8266's Avatar
Those are the right codes to delete. There is nothing you can do about the ABS light.
Old 12-28-2006, 12:08 PM
Irocss85's Avatar
why cant you just take out the cluster and remove the bulb behind the abs light? same for the asr light. its a pita, but cleaner/nicer loooking then looking at black tape forever.
Old 12-28-2006, 12:14 PM
brad8266's Avatar
yeah you can do that too
