EFI Live?
Old 12-27-2006, 02:31 AM
SuperZ's Avatar
Default EFI Live?
I havent seen much about it.Can someone tell em about it.Can I run a SD tune with it .No mass air 3Bar setup?Also do you just use the hand held to tune with this and not a laptop????
http://www.efilive.com/pc-61-22-flas...-and-tune.aspx
Old 12-27-2006, 02:45 AM
ringram's Avatar
A search on here will show plenty of guys with them. Its one of the top products.
Yes you can do SD tune, or even alpha-n with one of the free custom OS's. They support 3bar as well as features for NOS etc. I run SD only with a custom OS to retain adaptive spark, you have the choice of running open or closed loop too.
Check out their forums and/or download the software and have a play.
As for the unit. v2 will allow stand alone flashing and logging with a software update early in the new year. Currently you can check and reset DTC's without a laptop and do all the usual log and tune stuff. The software updates are free.
Old 12-27-2006, 02:58 AM
RedHardSupra's Avatar
just download the software (free and fully functional except writing of course) and play with it, especially with the scanner, its' amazingly flexible and powerful.
also, check out the efilive forums, a lot of smart people there.
Old 12-27-2006, 04:10 AM
TAQuickness's Avatar
EFILive is certianly the best tuning solution on the market - However with a '98z you will find the options for tuning are fairly limited (compared to '99+). I'm not sure how you'd work around the 3bar setup in tuning a 98.
Old 12-27-2006, 04:42 AM
SuperZ's Avatar
I know HPT just came out with a 3bar 98 program
Old 12-27-2006, 04:56 AM
ringram's Avatar
Good point.
