Whats the biggest size tire w/out rubbing
Old 12-27-2006, 12:09 PM
JD_Z28's Avatar
Default Whats the biggest size tire w/out rubbing
I'm goanna sell my 17x9 1/2's and go with 18x 10 1/2's in the back. I was wondering what is the biggest tire I can get away with without rubbing on the inner fender wall, I didn't want to hammer the wall in so I'm trying to find the proper tire that will fit without any customizing. BTW the rims I'm getting are the Z06 Motorsports.
Old 12-27-2006, 01:00 PM
Xsta Z 28's Avatar
Front 275/40ZR17.
Rear w/o mods a 285/35ZR18.
Rear with MINOR mods 295/35ZR18.
Old 12-27-2006, 01:47 PM
JD_Z28's Avatar
Originally Posted by Xsta Z 28
Front 275/40ZR17.
Minor mods being what? I'm guessing banging in the inner fender.
Old 12-27-2006, 01:51 PM
mcmillion's Avatar
What's the offset on your new wheels?
Old 12-27-2006, 02:58 PM
JD_Z28's Avatar
I'm not sure exactly what the offset is on the Z06 Replicas, I'll try to find out.
Old 12-27-2006, 04:54 PM
Xsta Z 28's Avatar
Chances are they are +58 mm offset. . . .
Minor Mods . . . Well as said time and time again, and as spelled out in the sticky above . . . some inner wheel well massaging with a BFH, possilbe adjustable panhard, and/ or a 1/8" spacer . . .
Old 12-27-2006, 08:46 PM
SpdFrk1990's Avatar
So if its a 18x10.5 rim with 58mm offset you can run 285's with no rubbing?
Old 12-28-2006, 09:10 AM
Xsta Z 28's Avatar
Most likely. The amount of massging I had to do with my 295's was very minimal, so with a narroer tire, I'd say the modding would be nil.
