Tune Up/Performance ?'s
Old 12-27-2006, 02:09 PM
LS1ne's Avatar
Default Tune Up/Performance ?'s
okay guys i have a 99 ss stock ls1 (just k&n filter). I want to get new plugs, ignition wires, fuel filter and an air lid. I know it'll run smoother once i do this. heres what i had in mind.
Delco rapid fire plugs(if they make them for this motor)
Granatelli Ignition Wires(are they better than Jacobs/MSD/Taylor)
Granatelli air lid or SLP?(let me know if there are better ones out there)
Let me know whats best for this motor.
Thanks guys!
Old 12-27-2006, 02:14 PM
cabech984's Avatar
Alot of guys run NGK TR55 spark plugs here. Any lid will work, go for the cheapest one you can find. IDK about the plug wires, I was probably going to get GM Delco wires
Old 12-27-2006, 02:59 PM
lsx24's Avatar
MSD wires are the most popular and work well with the ls1. Most lids are about the same but people say the SLP lid is built a bit better. TR55s are the plug for most ls1s.
Old 12-27-2006, 03:20 PM
JohnnyC's Avatar
Old 12-27-2006, 05:09 PM
presto_z's Avatar
i have ngk tr-55's.. msd wires and an slp lid and i love my set-up....
the ws6store (sponser) has a great deal on the plugs and wires... as for the lid they are all the same.. just get one with a good rep..
Old 01-11-2007, 03:04 PM
Phil8616's Avatar
If your going to run LTs, Id get MSD super conductors....
Old 01-13-2007, 10:30 AM
2002LS1Z's Avatar
I run MSD wires, NGKTR55s. A lid is a lid.
Old 01-13-2007, 10:52 AM
Tainted's Avatar
TR55's here also with stock wires. theres not much need to replace wires since its kinda hard for them to wear uot unless theyre torn or burned
Old 01-13-2007, 11:06 AM
cookba's Avatar
for his setup, what will he need to gap the TR55's to. i know different mods call for different gaps
Old 01-13-2007, 11:07 AM
Tainted's Avatar
they come pre gpaped I never checked mine the stock range should be fine
Old 01-13-2007, 03:06 PM
presto_z's Avatar
they should be gapped at .055
Old 01-25-2007, 01:09 PM
98silverz28's Avatar
how do you gap the plugs or find out the gap? ive looked and can't find the answer to this
Old 01-25-2007, 02:22 PM
ebear's Avatar
NGK TR-55s and replaced wires with new stockers
Old 01-25-2007, 04:35 PM
Tech Resident
ChocoTaco369's Avatar
the SLP lid is the best quality lid, bar none. it's the best fitting and is also the toughest.
most people use the MSD wires w/NGK TR-55's on the LS1, though a lot of people swear by the OEM GM wires and plugs, too. stay away from taylor wires as they seem to break left and right.
i have a napa gold fuel filter and i recommend it to you highly, along with ANY napa gold filter. i run a napa gold air filter, fuel filter, trans filter and oil filter. napa gold FTW!
