turbo kit destoys belts
Old 12-27-2006, 02:36 PM
jason02Z's Avatar
Default turbo kit destoys belts
i have a problem with part of my turbo kit its similar to the tti street kit. it gos through belts because it hits the thermastat housing.which i ground down to make room for the belt ..im guessing it the brackets for the altinator. anyone have this problem with kits like this im sick of changing belts
Old 12-27-2006, 02:56 PM
Brains's Avatar
Sounds like its a design issue with the bracket. Tiff doesn't have that problem with her QMP-style kit, but I built the alt. bracket from scratch and made sure the belt is well clear of the thermostat.
Old 12-27-2006, 03:01 PM
jason02Z's Avatar
yeah it seems to be..do u know of any place i need to find someone that has them
Old 12-27-2006, 06:56 PM
Boo"SS"t's Avatar
I think "smokinHawk" sells them for $120.00 shipped.
Old 12-27-2006, 07:08 PM
LS1Tech Sponsor
Slowhawk's Avatar
The alt. needs to be moved alittle or even an underdrive pulley might clear.(should have a SFI approved pulley anyways)
Old 12-27-2006, 07:22 PM
andereck's Avatar
What?? A turbo kit is killings belts? I though you turbo guys liked to bag on blower guys about their belts. This is funny ****!...well maybe not to jason02Z.
Old 12-27-2006, 07:29 PM
Turbo Addict
RICE ETR's Avatar
I am running the QMP/stainless works brkt and mine was throwing belts like crazy too, i even added a manual tensioner...didn't work...then i took the time to align everything perfectly and it hasn't done it since.
Old 12-28-2006, 08:51 AM
Ponyhntr's Avatar
Old 12-28-2006, 09:07 AM
6 Second Club Moderator
LASTLS1's Avatar
I've never replaced a belt. I guess it's the kit you buy.
Old 12-28-2006, 09:30 AM
smokinHawk's Avatar
which alternator bracket do you have?
if they are off just a slight bit they can throw a belt or chew one up. I have made a couple that were off just a slight bit, i had the people send them back to me and i re-aligned them and they reportably work better then
the one i use for my self is close to the thermostat housing but does not touch, also i have noticed some thermostat housings are slightly different from eachother, the one i got from autozone is smoother and has more clearance from the belt.
any pictures of your problem?
Quick Reply: turbo kit destoys belts
