car dosent idel right with out tranny
I took my 4l60e out to see if thats where a noise was coming from in my car.. i plugged the rear 02 sensors back up then i started it its isnt ideling right is this beause the tranny isnt hooked up or is it possible maybe i just unplugged somthing... it tries to fix the idel it idels up and down trying to smooth out but eventualy it dies unless i keep the rpms up... any help would be great... i was thinking maybe i pulled somthing loose pulling the dipstick out or just rocking the motor by pulling on the tranny
LS1Tech Sponsor
I would agree you may have something pulled loose , Also a word of advice make sure that the wiring harness is clear I have seen then wrap up in the flex plate when doing that and its a mess I would try however plugging in the PRNDL switch also as the Engine idle may ajust to some amount based on gear selection .
__________________
well see mines runs fine for a little bit like 40 seconds or so then starts to idel up and down trying to get it right ya know ... thanks for all the input guys !!!!
