lt197formula
12-28-2006, 06:18 PM
Haven't heard or seen much more than these links and a couple others but if Dodge follows through with it props to them. Looks better and will have more power but then of course GM will up the ante with the ZOsick or whatever is going to happen with the bluedevil??? Either way in the future the cars are just going to keep getting unbelievably sicker :devil:
http://www.fquick.com/articles/2008_Dodge_Viper_SRT-10
http://forums.corvetteforum.com/showthread.php?t=1447881 (this information is copied and pasted below)
Fourth Generation Dodge Viper and Chrysler Firepower Rumors:
Late next summer the last 2006 Viper will roll off the lines. When the employees return to work the following January, a little over 14 months from now, they will be building the refreshed 2008 "ZB" models. The 2007 model year is going to be skipped.”
From a source who would probably prefer to remain nameless: “The 2008 Dodge Viper is solid - much faster and sleeker, while still keeping the twin hump in top (on coupe models) but with a whole new front end that’s sharper and more menacing.”
Given the recent showing of a McLaren Viper, and rumors about the current V10 being “made over” by an external firm, it seems almost certain that the 2008 Dodge Viper will use a McLaren-massaged V10 engine, probably the one shown at SEMA in the ASC Diamondback Viper. That engine was rated at 615 hp, a fat 110 hp more than the current version; that Viper could do 0-60 in 3.5 seconds, a few tenths better than the current model in a genre where a few tenths are a big difference. The ASC model cut weight using expensive carbon fiber, but then, McLaren might not have been showing all their engine could do; we’ve been told to expect 700 hp but we suspect 650 is more realistic, and, indeed, we have been told by a reliable source that 600-650 hp is what we should really expect. Keep in mind, though, that the Viper V-10 is not a typical "peaky" engine and that it has tire-melting power right off idle.
Other rumors were not particularly credible - using the Mercedes V12 (not Viper-like), a V10 Hemi (expensive to create, poor emissions), a turbocharged V10 (not desired by current owners), and an even bigger Hemi V8 (again, not Viper-like). The current Viper engine, based on the LA V8 family introduced decades ago, most likely has untapped potential which could be awakened by expert tuners.
A Chrysler version of the Viper is almost certainly in the works. The Firepower may be a look at what's to come - it's a Hemi-powered, Viper-chassis Chrysler that would be cheaper to make, and would add to the volume of the Viper chassis, helping to spur profitability. By using a standard-production drivetrain, it's no doubt much cheaper to make - and performance is still respectable with a Corvette-like 0-60 in 4.5 seconds. (Keep in mind it's an automatic.) The Firepower is said to have definitely been approved.
2008 Dodge Viper rumor roundup summary:Predicted debut: 6:30pm-8:30pm Monday September 25th, 2006, VOI9 Las Vegas
Start of production (Job 1): January 8th, 2007
End of production: July 2008 (for the 2008 model)
Series: ZB
Models: SRT10 coupe and SRT convertible (+ Special edition models)
New features:
Exterior refresh
8.4L SFI V10 engine replaces 8.3L V10 (600-650 hp estimate)
High performance alternator
New SRT-10 satin silver badging
Key carryover features from 2006:
6-speed T56 manual transmission (revised?)
3.07 axle ratio
12-inch clutch
18.5-gallon fuel tank
18x10 and 19x13 wheels
275/35ZR18 and 345/30ZR19 Michelin tires
310-watt amp w/7 speakers and subwoofer
Anti-lock 4-Wheel-disc brakes
Dual side exhaust
HID headlamps
Keyless Entry
Leather wrapped Steering Wheel
Power adjustable pedals
Power windows (1-touch up)
Preferred suede seats w/leather trim
Radio RBQ AM/FM radio w/in-dash 6-disc CD
Sirius satellite radio
Sport Suspension
Tilt steering column
Colors: Viper...black, blue, red, yellow, slate crystal?, more?
Series: ZB
New features:
Exterior refresh
3.07 axle ratio
12-inch clutch
Dual side exhaust
HID headlamps
Keyless Entry
Sport Suspension
