6.0 heads on LS1, what head gaskets do I need?
I have 6.0L (317) heads on a 98 ls1, and I want to go with gm mls gaskets. Are LS1 gaskets the same as the 6.0 gaskets or is there a difference?
Thanks
Brad
Thanks
Brad
Originally Posted by motorsports601
so for boosted the stock mls work good? low compression and medium boost 15psi?
6.0L MLS gasket GM part #12589227 in case you needed it.
And they should do just fine. I'm using them on my current project which has a 101 attached to it. Not running yet but we'll see how they hold up.
Originally Posted by ls1king000
YES
1999-2000 lq4 (cast iron) 9.5:1
2001+ lq4 (aluminum) 9.4:1 - 317 casting
2002+ lq9 (aluminum) 10.1
compression is on a 5.7
i bought a set of 317 castings for $300 with less than 5000 miles on them. Yep you'll be fine, these are great heads for boost
I'm in the same boat, but The heads I've come across are fully ported. I'm still a 346ci, would fully ported 317's be a good idea? sorry for the hi jack Also can you pull the heads off in a car if you go studs over bolts?
My 317's are ported also. Your fine put them on!
YES
