whats the difference GU2 or GU5 Z28's?
not sure if i need to post this here or somewhere else but what is the differences of the 02 Z28's with the GU2 Code and GU5? i know the GU2 has the 2.73 and the GU5 has the 3.23 but what else is different? also doesnt the GU5's come with aluminum driveshafts and the GU2's dont?
LS1Tech Administrator
Received 1,491 Likes
For the LS1 years:
GU2 = 2.73 gears and steel driveshaft
GU5 = 3.23 gears and aluminum driveshaft
its not like the GU2's are known for breaking more than the GU5's or anything?
The only issue I can think of is with the aluminum driveshafts on the 3.23 cars. They’re prone to making a “tink” type of noise when shifting into gear. I’ve had two GU5 LS1 cars and they both made this sound.
The steel driveshaft GU2 cars will not make that noise.
Originally Posted by gyrene2003
cool, so the aluminum driveshaft is lighter right?
Tech Resident
damn steel driveshaft. i wish i had the money for a high performance one...
Originally Posted by ChocoTaco369
yea, we just have vibrations out the ***
Mine doesn't have any such vibration. Been up to 120-130mph a couple times with this car, no vibration at all at any speed. I'm very happy with my "tink"-free steel shaft.
What speed does yours vibrate at? Are you sure it's not tire/wheel related?
Tech Resident
Really? I know some LT1 cars had this issue with the steel shaft, but I thought it was resolved by the LS1 years.
i also get this horrible rattling from what feels like my console at about 50 mph exactly ONLY when my car is locked up in overdrive...but it seems to only happen when it rains, and not all the time. i don't know what the hell is up with that?
i just get a slight vibration through the gas pedal.
If you still have a stock mount, have you checked it for any cracks/damage?
Also, might not hurt to get your wheels/tires rebalanced if it's been a while.
Maybe your driveshaft needs to be rebalanced.
I would try all that stuff before spending the money for a new driveshaft. All I can tell you for sure is that my 2.73/steel shaft car doesn't have any of the issues you've described....
Tech Resident
Is this the case at any speed?
That's an odd one. Just an idea,.... are you using a stock trans mount, or a poly one? Poly will vibrate a lot.
i really need to get this car up in the air
