Washing Rocks Sound...Normal?
Old 12-29-2006, 09:06 AM
lt1kitten's Avatar
Default Washing Rocks Sound...Normal?
My LT1 T56 makes a washing rocks sound at idle. It's pretty erratic, and it goes away when the clutch pedal is pushed in. I recently swapped from an A4, so I'm not sure if this is a normal T56 thing or if I have an issue. The trans was fully rebuilt, it has a new clutch, pilot bearing, throwout bearing.
Old 12-29-2006, 10:03 AM
SladeX's Avatar
I get that sound too, it's more prevalent if I'm lazy and put a little pressure on it in fifth gear from my hand on the shifter. I'm pretty sure it's the transmission making the sound as I changed my clutch, pilot bearing, slave and the sound was still there.
Old 12-29-2006, 10:19 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Yep...I get the same sound with the clutch engaged (in neutral)...as soon as I push the clutch in, it goes away. I was told the bronze fork pads in mine would make some extra noise...
Old 12-30-2006, 05:23 PM
blown90lx's Avatar
sounds like a throwout bearing to me.
Old 12-30-2006, 05:24 PM
blown90lx's Avatar
ive seen new throwout bearings come apart at first startup.
Old 12-31-2006, 12:32 AM
SladeX's Avatar
I replaced my throwout bearing with a new one when I upgraded to the 01/02 slave. I still get the same sound, save for the fact it's only in 5th gear and when I'm coasting and putting pressure on the shifter. Seems like there is a bit of "play" internally to the transmission. If it's under a bit of load then the sound gets real quiet, almost gone, but still faintly heard.
Old 12-31-2006, 10:40 AM
ls1amit's Avatar
mine does it too made me freak out when i first got the car its actualy quite noisy but hey no grinding here so im alright.
Old 01-02-2007, 04:24 PM
99WS7's Avatar
I have that sound in neutral too, my new Textrilla 0z700 only has 400 miles on it so it may still be breaking in but from doing a little searching in it seems to be normal...it just freaked me the hell out, not exactly a cheap clutch.
Quick Reply: Washing Rocks Sound...Normal?
