Cam Guru's: What about this one?? Look inside...
Old 12-29-2006, 01:00 PM
Rebelord's Avatar
Default Cam Guru's: What about this one?? Look inside...
224/240 .636/.609 109+4
LSK/XE-R lobes
Intake Valve opens - IVO 31.5 7 -30.5
Intake Valve closes - IVC 61.5 37 -0.5
Exhaust Valve Opens - EVO 77.5 53 13.5
Exhaust Valve Closes - EVC 31.5 7 -32.5
Exhaust Centerline - ECL 113 113 113
Overlap 63 14 -63
DCR: 8.47
For a stock headed LS1 with LS6 intake and full bolt ons.
Am I nuts or good to go??
Ski
Old 12-29-2006, 01:07 PM
brad8266's Avatar
sounds kinda overkill to me, im by no means a cam expert though. No way id run stock heads with it, that for sure.
Old 12-29-2006, 01:09 PM
SStrokerAce's Avatar
Nuts
One reason why some people never give advice on here about cams is that just designing your own cam to arbitrary specs and then posting them up without any real information on what you want the car to do or what the car has on it is
Good Luck,
Bret
Old 12-29-2006, 01:10 PM
brad8266's Avatar
Originally Posted by SStrokerAce
Nuts
Good Luck,
Bret
Old 12-29-2006, 01:27 PM
pianoprodigy's Avatar
Why don't we tell him what's wrong with that cam rather than practically telling him he's an idiot?
The first problem I see is that the IVC is 37. From what I've read, that's way too low and will peak very low. Also, I don't see any reason to have a 16 degree split on stock LS1 heads. There's a reason most every cam out there is a positive 2-6 degree split.
What are you trying to accomplish with your cam swap? I assume you have an auto which will influence your cam choice. What stall?
Old 12-29-2006, 01:32 PM
brad8266's Avatar
I didnt give any real advice because like i said, im not a cam guru, although i know some stuff.
Old 12-29-2006, 01:34 PM
Understood. I'm no guru by any means, but I like to try to help. I can at least get him started by asking some questions.
Old 12-29-2006, 01:53 PM
OhIt'sBeenBraughten's Avatar
I don't understand why everyone wants to re-invent the wheel around here. There are plenty of proven cams that have been designed by some pretty knowledgeable folks.
Old 12-29-2006, 03:05 PM
Rebelord's Avatar
guys...here
by no means am i in no way trying to re-invent the wheel. Im trying to develop a cam to create the most cylinder pressure to create the most DCR to make torque. you make torque you make power. I am reading, learning as much as i can about cams, valve events and understanding how it all works together. so, if i can create a 8.47:1 dcr and have enough overlap to help the stock heads scavenge to suck in more fuel/air mixture to make more power. because the heads are low flow restricted and will have a hard time with the upper rpms to continue to create the power. thats why i included the lsk lobe on the intake. like i said i am still learnig. however, i believe if this cam can create excellet torque down low and hold the power up top. then it can be a good daily driver with some good weekend track abilities. look at the MS4 239/240 .643/609 111lsa(dont know the advance) creates a 7.47DCR to my calculations. (if im wrong, point me in the right direction) It creates good power, however i believe it can be used in a better situation with good flowing heads. well, thats all i have.
Ski
Old 12-29-2006, 03:20 PM
LS1 Tech Administrator
Patrick G's Avatar
That cam will actually work pretty well, but it's not ideal.
Here's what I like:
Big lobe area without too much duration on the intake side.
High DCR with stock heads.
Overlap biased to the intake side of TDC will allow the motor to pull past its hp peak (probably around 5800 rpm)
Narrow LSA gives nice valve events for area under the curve
What I don't like about it:
The exhaust split is a little too extreme for someone running LT headers with no cats. It has a little too much overlap if you were running cats.
A nice compromise of this cam would be:
224/232 .636/.595 109LSA +2
IVO 5
IVC 39
EVO 47
EVC 5
Overlap 10 (centered exactly over TDC)
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 12-29-2006, 03:50 PM
N4cer's Avatar
Don't ya think an 8.47 DCR is less than optimal? I thought 8.5-8.8 is optimal.
Old 12-29-2006, 04:32 PM
Patrick G's Avatar
It is, but since this person is starting off with a 10.1:1 static compression ratio (stock heads), achieving a DCR above 8.5:1 is nearly impossible without a terribly early intake valve closing point. When you have over 11.0:1 SCR, hitting 8.5:1+ DCR is a lot easier!
__________________
Old 12-29-2006, 04:44 PM
ArrestMeRed99Z28's Avatar
I'm in the exact same boat with the fella that started this thread, want to make some good power with bolt ons and a cam with out spinning to the moon, this cam sounds great. What would the dynamic compression ratio of the 224/232 109+2 with stock heads&gaskets be? Can some one point me in the direction of a good calculator? Wish there was one like that gear calculator!
Thanks
AJ
Old 12-29-2006, 05:15 PM
LS1Formulation's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/630637-my-dcr-calculator-if-you-have-comp-grind-doesn-t-get-any-easier-than.html If you have a comp grind in mind, there you go!
Now, I keep studying more and more on my personal cam design and wonder if I could run a 226/230 XE-R lobe cam on a 107+2 LSA. On smaller cams I would think running a narrow LSA would be more beneficial to helping build torque down low. Can I hear some opinions as to whether or not this would be a possible design?
Old 12-29-2006, 06:02 PM
Hype's Avatar
I made a thread asking about making DCR without higher SCR, and that answers my question haha. Thanks
Old 12-29-2006, 06:40 PM
Rebelord's Avatar
Patrick, now since im in the Marines and we finally have some time off, ive been drinking. but thank, you. i will respond when i get more sober. but finally im undertstanding how everthing works together. I will look at your exact specifacations further and see what your talking about. but however, what about i thought that 8.7DCR is better souted for higher flowing and better exhaust applications???
Ski
Old 12-29-2006, 06:48 PM
JPH
JPH's Avatar
what gear and converter combo is in this car?
Old 12-29-2006, 07:26 PM
cws T/A's Avatar
8.2 :1 67cc / .055 stock
8.5 :1 67cc / .040
Old 12-29-2006, 09:00 PM
Ragtop 99's Avatar
Where are you trying to make the power? Even with an early IVC, having a ton of overlap is going to result in poor low end power (e.g. 2000 - 2500 rpm), although the torque should build very rapidly.
Old 12-29-2006, 10:04 PM
eLTwerker's Avatar
If IVO is 7* BTDC and EVC is 7* ATDC wouldn't the overlap be centered about TDC? This is where the overlap occurs, correct?
Quick Reply: Cam Guru's: What about this one?? Look inside...
