Next step above 76GTS
What would be the next step up in turbo's above a 76gts for a T4 flange? This would be for a built 346 with 317 heads, turbo cam etc.
Primarily still a street car but at least 100 passes a year at the strip
oh and it needs to be physically almost the same size as the 76
Originally Posted by Smearin
76 is good for that size motor why would you want to go bigger?
80 would be next... or a 76 t6 flange.. or a s76
Are the S stuff T6 flanges?
Yea they are.. they're awesome units..
76 would be perfect for a 370 or 346.. I think you can upgrade wheels on the 76 to 80.. not 100 % tho..
maybe someone will chime in on that..
Originally Posted by DrTurbo
Go with a GT-M from T-netics. They are a bit pricey but awesome pieces and use a T4 flange.
BTW, the S-series turbos are T6, but they will make crazy amounts of power and are pretty much indestructible.
the s series are mid framed.. and from what Dr. Turbo has told me.. they are the same size as a gt42
theres a thread in here that tells the spool of the s-series but i hear they spool quicker in comparision to smaller turbos
Originally Posted by TURBO383WS6
80mm of some sort.
Originally Posted by MIGHTYMOUSE
the largest t4 (and the only step up imo) is the pte-88 and it is larger all over than a 76
