I think my LM1 took a dump :(
So it was working fine and then all of a suden im getting error's and too rich on the display and then i can shut it off and turn it back on, then it will work for a few seconds then it will start to false peg out at 20 afr for a second then work, then false peg again, the first thing i thought of was my grounds are cuming loose, so i checked and they were ok, but the digital reading on the lm1 it self was peging out, not in hp. So what would cause that false peging, a bad lm1 unit?
Moderator
20:1 is the free air number and could be an electrical
intermittent or a sensor going out. Might reseat the
sensor connector and wiggle the DIN connector at the
LM-1 too. I suspect that a bad sensor would have more
consistent badness.
consistent badness.
I already had a bad sensor that i replaced due to excess oil entering the engine from a faulty pcv, but thats all be sorted. Then i start having this ploblem, Im goin to racal it and check all the connections and see, i dont think its the sensor or the a connections tho.
Turn on the sensor (LM1 box) let it warm up, hold the sensor by the wire letting it hang, hold a cigarette lighter directly below the sensor and (without striking) hold the gas open on the lighter the AFR #'s should drop to 0 if the sensor is working properly. If it moves very slow to 0 or won't go to 0 the tne sensor could be getting old/tired.
