Stereo & Electronics - Y Not To Run 4 Ohm Speakers @ 2 Ohm
Craiggg
12-30-2006, 12:33 AM
http://www.youtube.com/watch?v=ldHRfFAWC7Y
Plus it loves to blow fuses. Plus it ruins the speakers. Yes this is in my car.
CULATR
12-30-2006, 01:22 AM
yikes!!!
cookba
12-30-2006, 01:34 AM
wow and there are so many topics on here that say runing 4 ohm at 2 ohm is ok.
WhiteBird00
12-30-2006, 07:51 AM
No, the topics on here say that running a 4-ohm speaker in place of an original 2-ohm speaker is okay. That's true because the higher impedance reduces current (and volume) but doesn't cause any problems. The opposite is not true - you should never run 2-ohm speakers in place of original 4-ohm speakers unless you know that the amp is 2-ohm stable. Reducing the impedance increases the current flow and thus generates more heat which can seriously damage or destroy components.
H21surfer
12-30-2006, 09:03 AM
like white bird said, going the other way will result in buring your voice coil. A speaker is really almost never "blown," it just gets a little melted where the wire coils up causing the Electromagnet to have a defect. the way you have is fine, but it could be louder and a little more cleaner with 2ohm speakers (however, maybe he stock speakers should have been 4ohm because mine keep on burning up).
Richiec77
12-30-2006, 09:37 AM
Add to it Distortion increases Exponentialy when you start dropping resistance. So at 4ohm's, 0.001 THD becomes 0.01 THD at 2 ohms, 0.1 THD at 1 ohm.......etc etc.
Reality is probably 0.5 thd 4 ohms, and goes on from there.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
