converter intsall..what to expect?
well i have transmision fluid, and filter, and my converter do i need anything else for theinstall? also i have seen a bunch of horror stories lately abou not beng able to get the flexplate bolts out and such, should i be worried about this on my 20k mile car? I'm not afraid of work, but i don't like running into problems that i an't fix on the spot. Will i be able to reuse my stock converter bolts? do i ned a new flexplate? sorry for the questions guys...
someone its hard to get straight answers on here. so far i have figured out that the 02 car flexplates suck, and should be replaced but the TCI one doesn't work very well with my YANK, and the flexplate bolts suck ***** and are hard to get off....what am i missing
The issue with negative feedback on the TCI flexplates (as I understand it) is that they manufactured the torque converter attaching bolt holes larger than the factory 10mm size hole. It was done that way to accomodate their converter I believe. It should pose no issue it the powder coating is scraped off around the holes and red locktite is used with new bolts.
As far as getting the converter out. It can be tough laying on your back. Been there done that. Whatever you do disconnect the battery first! If you leave the cable at the starter connected when you remove it, it will short and create massive electrical problems. Then remove the starter. Then rotate the engine and remove the T/C bolts being careful to not round them off... use a good socket.
After that, remove the driveshaft, linkage, crossmember, cooler lines and electrical connector. Thats the rundown on how to get it out right?
As far as installing the converter to the transmission... it will be fully seated when you cannot slide your hand between the converter and the pump. When installing it be careful not to disturb the pump seal, support the converter from the bottom as you insert it. Once it is up on the pump stator and input shaft begine to rotate it either direction while pushing forward slightly. You will hear a clunk or two. Then ck to be sure it is fully seated. Hope this helps.
g
g
Well I have been working on mine the last two days. So I will share with you the issues I faced. I spent Saturday prepping the car unhooking electrical and getting the top trans bolts off. These bolts where actually pretty easy to get. Then I took the bolt out for the dipstick tube and yeah that was fun. Thank goodness I have long arms. I called it a day and drove to get my friends trans jack. The two most time consuming things where the torque convertor bolts and pulling the trans itself off the dowels. I have a small pencil torch from harbor freight and I could not get the TC bolts loose so I hit it with the pencil torch and got them all out. I was afraid of stripping cause I have a 98 with allen heads. I would think the torque bit ones would be even more easy to do this to. I dot know if this really worked but it gave me more confidence to pull harder on the bolts. Once those were out trying to get the trans disconnected was the toughest thing. We could not get it loose for anything. So I just soaked the dowels and waited then pulled the access cover on the drivers side and it pryed and pryed. I was so happy when it finally popped. I know that if I was to do it again I could have saved myself close to 4 hrs and be done today. Now I just have to basically put the starter back up and connect all the stuff I took off on Saturday. Good luck and if you have any quesions just ask.
