Stereo & Electronics - "Security Light" Problem ...
mighty-z28
12-30-2006, 02:56 PM
I have a Clifford Matrix 3.5 in my Camaro Z28 for a year
and today when I try to start the car nothing hapened !!! and the
factory "Security" light is on... I try to desactivate the factory
alarm with the factory remote but still on ??
Any idea how to fix this ???
Thanks guys.
WhiteBird00
12-31-2006, 07:45 AM
The factory security light on the dash has nothing to do with the alarm system (either original or Clifford). It is part of the VATS Pass Key II system that checks the resistor pellet on your key to ensure the correct key is used to start the car. Usually, the problem is caused by dirt and grime on the contacts causing an increase in the resistance so the system thinks the wrong key is inserted. It can be solved by using your spare key or cleaning the contacts on the key with a pencil eraser and some rubbing alcohol. Sometimes you need to clean the contacts inside the ignition cylinder by spraying some contact cleaner (Radio Shack) into the key slot.
mighty-z28
12-31-2006, 02:44 PM
well It wasn't that, but you give me a pretty good idea of what it was... It's actually the remote start, I think that the bypass circuit or the connection is bad... I'll take it to the alarm place...
Thx for your help and Happy New Year to all.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
