H/C set up questions
Old 12-30-2006, 04:43 PM
crazylane's Avatar
Default H/C set up questions
What are the recommended Injecters for a H/C setup? With full bolton's. Thanks in advance
Lane
Old 12-30-2006, 04:56 PM
sdbrown84's Avatar
Most are ok with stock injectors, however while you are in there you can upgrade them for later use (assuming you get the proper tune). I put 42 lb Delphi injectors in at the time of my swap.
Old 12-30-2006, 04:59 PM
crazylane's Avatar
okay cool man. thanks for the info
Old 12-30-2006, 05:08 PM
M6HuggerSS's Avatar
stick with stockers until you tune to find out if bigger ones are needed.
