Retorqued my heads, do you think it's okay
Old 12-30-2006, 07:45 PM
Rothman's Avatar
Default Retorqued my heads, do you think it's okay
Drivers side head was leakin coolant onto my headers when heated and under pressure. I just retorqued both heads, the drivers side was only about 5 ftlbs off. Using commetics with copper spray BTW. Do you guys think that 5ftlbs is enough to allow a leak or should I look elsewhere? They were not leaking untill I put a few miles on it. I don't want to put everything back together unless I'm fairly sure that It won't leak again.
Old 12-31-2006, 04:20 PM
crainholio's Avatar
Assuming you're running aftermarket head bolts that aren't torque-to-yield design, then I'd say no issue...as long as you followed the recommended torquing sequence.
It used to be common practice with engines to re-torque the head bolts after a heat cycle or two.
You might want to add a pellet or two of cooling system sealant for good measure, but if it still leaks after this you'll be removing the head(s).
Old 12-31-2006, 07:30 PM
Rothman's Avatar
Well I threw some liquid aluminum coolant stop leak in and put it back together. Doesn't seem to leak anymore but I'm going to keep an eye on it.
Thanks!
Old 12-31-2006, 08:26 PM
pdd
pdd's Avatar
good luck with it
Old 12-31-2006, 11:47 PM
racecar's Avatar
Leaking gaskets, Ouch. I try to avoid sealers in the radiator because they can plug up other things. Retorque was a common practice with high compression small blocks. As the above post said, if you are using an aftermarket bolt, that should work. If you are re-using GM bolts all bets are off.
BTW, do you have a good torque wrench, I had a leak and found that the old low budget torque wrench was off by 15%.
Old 01-01-2007, 01:34 AM
HAMRHEAD's Avatar
Always retorque but after you do you should be fine even wit out adding the coolant stop leak
Old 01-01-2007, 09:41 AM
MiaSSmaro98's Avatar
rothman what bolts are you using?
Old 01-01-2007, 10:33 AM
vettenuts's Avatar
He can't be using stock, there is no torque value. They are preloaded based on rotation, not torque.
Old 01-01-2007, 11:43 AM
Charlie@LsXperts's Avatar
once you take the stock bolts out you have to replace them, when they stretch they wont do anything again
Quick Reply: Retorqued my heads, do you think it's okay
