weld draglites ??
Old 12-31-2006, 07:48 AM
1fast01's Avatar
Default weld draglites ??
I have a 2001 fbody; was wondering what length wheel studs should be used for stock brake system with 5/16 spacers on draglites... also where you all bought them
Old 12-31-2006, 04:02 PM
chevynut50's Avatar
I just installed a set of Draglites on my 97 Camaro using a 5/16 spacer. I installed ARP 3.25 inch long studs from JEGS. There is about 1 to 1-1/2 thread exposure on my open end lugs.
Old 01-01-2007, 07:29 AM
1fast01's Avatar
thanks that helps a lot' it was either between those & or the 2.5's; I guess the 2.5's will work then
Old 01-01-2007, 09:41 AM
chevynut50's Avatar
Smile
I wouldn't use open end lugs. Use the closed end lugs if you're using the 2.5 inch studs. Using the 2.5 inch lugs you're not going to use the full extent of the lug thread engagement only about the length of the shank.
Old 01-08-2007, 02:10 PM
xxxtreme36's Avatar
i have the same issue, so what would be the ideal size stud and spacer for the stock brake setup and the draglite skinnies
Old 01-08-2007, 05:15 PM
chevynut50's Avatar
I have a 1997 Z28 Camaro with the stock front brake set up. I used ARP 3.25 inch long studs and 5/16 inch spacers along with open end lugs. I would only reccommend the 3.25 long studs for the front. I will be changing my stock rear studs to 2.5 inch long ARP studs next.
