PVC Quick Question PIC Inside!
Old 12-31-2006, 09:50 PM
CustomInductions's Avatar
Default PVC Quick Question PIC Inside!
Hey guys I need help...I have been reading for hours...and I cant figure this CRAP out....I have a one way check valve..and this is what I have so far....The check valve is facing forward to the PVC....is this right?? Im not sure if it is...cause the car hesitates and has no throttle response...but I thought this is what I read somewhere....It was late so I didnt get to try it the other way....just need some info on how I have mine hooked up!!...Thanks guys!
Old 12-31-2006, 10:14 PM
Wnts2Go10O's Avatar
PCV, pvc is home plumbing. just take the valve off and run some air through it to make sure youve got t right. although, there might be a little marking on it to tell u which way its supposed to go.
Old 12-31-2006, 11:24 PM
I have the arrow marked on the direction it is going...i just didnt know how everyone else had it hooked up!?!?....LOL....sorry PCV
Old 01-01-2007, 02:27 AM
Wnts2Go10O's Avatar
get rid of the tb line all together. the vac from in front of the turbo s whats pulling it all in. the tb isnt doing anything.
Old 01-01-2007, 08:28 AM
2001WS6Vert's Avatar
Unless I'm not reading this right, you need to have direct vacuum from the throttle body to the PCV with the check valve in between. You won't supply any vacuum to the PCV if you first go to the catch can, you'll only create a vacuum leak.
Old 01-02-2007, 10:05 PM
That is what the air filter tap is for though....its supposed to keep vacuum on pvc...is what i was told...i tried it both ways and still leaking oil out the inlet side =0(
Old 01-03-2007, 07:03 AM
I would run a separate hose with a check valve in between to the PCV. Connect all other vent tubes to the catch can. The vent line from the can if connected between the air filter and throttle body will create vacuum for the catch can under high airflow conditions.
Old 01-03-2007, 07:59 AM
TT-TECH Veteran
Inspector12's Avatar
Block off the TB port as it is designed to be the air intake for the PVC system, but you are doing that by moving it to the filter on the turbo. Run the port behind the TB just like you have it with a check valve. If you don't have a check valve on the TB you will be letting boost go right through but you don't need it at that point so just plug it.
Old 01-03-2007, 11:15 AM
got ya!! that makes since....i guess it would be putting boost into my canister...Thanks!!
