pulling motor/trans
Old 01-01-2007, 12:16 PM
partyhardoo69's Avatar
Default pulling motor/trans
I think this is where this should go...if not please move it.
I'm about ready to pull the motor/trans out of the car. But I still need to get the torque arm off the tranny. What is the best way to do this? i see the three bolts on the bell housing. I'm having a hard time getting to the top bolt but once i get that off it still doesn't look like the tq arm is just going to pop off.
Once this is off the motor should just about be ready to come out the top. Also, Does the water pump need to come off?
thanks,
Eric
Old 01-01-2007, 06:30 PM
J's99Zrated's Avatar
I am in the process of pulling the motor too, but it is coming out of the bottom of the car. You are on the right track by removing the top bolt on the mount.... just keep working at it, it will come out. After you remove the bolt I used a large screw driver to pry the mount open. Also don't worry about the water pump I am leaving it on the engine.
Old 01-01-2007, 06:33 PM
thanks for the reply. I got it all out. A/c had to come off, and so did the alt. Water pump also came off too. all in all two days isn't too bad for our first time pulling the engine.
Old 01-01-2007, 06:58 PM
FDXHAWK's Avatar
Do Most Pull The Engine From The Top Or Bottom
Old 01-02-2007, 01:28 AM
HAMRHEAD's Avatar
Most do it from the bottom as it is easier.
Old 01-02-2007, 08:18 PM
Gm put the engine in from the bottom at the factory, and it is easier to remove that way just as Hamrhead said.
Old 01-02-2007, 08:24 PM
Cop Car's Avatar
took me 4 hours from start to finish to have the motor out the bottom
Old 01-03-2007, 07:43 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Moving to General Maintenance (from General LSX Discussion)...
Old 01-06-2007, 06:09 AM
ATwelveSec02Z28's Avatar
I just pulled my engine this week - Came out of the top in about 2.5hours. Having tubular k member and spohn solid motormounts made the job simple.
