T3 T4 garrett turbo question
Old 01-01-2007, 03:48 PM
bac12476's Avatar
Default T3 T4 garrett turbo question
Its hard to find some one that really knows what there talking about. I have a t04e 50 trim , that has the t4 exhaust housing. The bushing spun and took some of the steal out of the center of the turbo making the new bushing slight loose which is making too much side to side shaft play. Im looking to buy at t3t4 60 trim that comes with no housings. Do you know if this will fit i want take my rebuild kit to build this core and change my to4e 50 trim to a 60. If it wont fit could I use my T4 turbine shaft and housings and use the t3t4 center of the turbo and 60 trim compressor wheel . I was told that the 50 57 and 60 trims all use the same compressor housing Is that correct?
This is going in my 99 yukon denali 5.7 I was getting great Boost out of the to4e 50 trim before the Bushing blew on me. I think it ran dry for a few mins and thats all it took to wear the bushing.
1. can a t3 turbine wheel be used with a t4 housing ?
2. can a 60 trim compressor wheel be used in the same housing as a 50 trim ?
Old 01-01-2007, 04:54 PM
disassembled's Avatar
This would probably be a good question for Jose at forced inductions or limitengineering.com. Sorry to not be of anymore help.
Old 01-01-2007, 05:09 PM
cablebandit's Avatar
Jose at forcedinduction.com or Chopper or John Craig at limit engineering will know.
