LS1 block bellhousing pattern dimensions needed for adapter
Does anyone have a source or drawing of the bellhousing pattern dimensions for fabricating a transmission adapter? I think they would be ordinate dimensions about the crank centerline.
Thanks
Thanks
The bolt pattern is the same as a GEN I SBC with the exception that the 1:00 o'clock position (when facing the block) is not used. They also added the two bottom positions, but some folks don't use them. I used to have a drawing somewhere; otherwise the GEN I will get you started. The dowel pin positions and their bore diamemters of course require the closest tolerance.
Andy1
Andy1
Be aware that there are housings inside of the bellhousing area that will not allow a plate to set down flush with the mounting surface. I had to cut out the block plate for my Gen 1 scattershield to set flat.
belhousing, bell, bellhousing, block, bolt, dimensions, dimenstions, dowel, housing, locator, ls1, pattern, pin, size, transmission
