did i do this right!
Old 01-02-2007, 09:11 PM
TXZ28LS1's Avatar
Default did i do this right!
alright guys! this might sound corny and all, but i just wanted to make sure i did this right. i checked my coolant over flow and it was low, so i added coolant andadded 1 bottled water in the overflow to top that off. then i checked the radiator and that was low, so i did what the owners manual said added coolant until topped off. but i didnt add water. am i good to go! sorry sounds dumb but i just want to make sure.
Old 01-02-2007, 09:39 PM
sp00rkz's Avatar
Yeah, your fine. As long as you didn't mix coolant colors.
Old 01-02-2007, 09:52 PM
TXZ28LS1's Avatar
haha..thanks buddy for the reply. yeah i just wanted to make sure i did that right. i just checked my ac and that $Hit blows cold as hell now too..i heard the fans kick i believe and the heater and everything works fine. i just wasnt sure if i was supposed to add water in the radiator also or just the over flow?
Old 01-02-2007, 09:56 PM
sp00rkz's Avatar
Basically you can put water wherever you want, just as long as you have some antifreeze in there.
Usually people in warmer climates who race a lot run straight water. Water is what keeps your engine cool, Antifreeze just keeps it from turning to ice.
Old 01-02-2007, 11:12 PM
Da Swami's Avatar
Antifreeze also prevents the internals from rusting or corroding.
Old 01-03-2007, 05:05 PM
TXZ28LS1's Avatar
thanks guys. my buddy told me also, all i really needed to do was fill the overflow only! but i thought u had to add coolant in the radiator also.
Old 01-03-2007, 08:58 PM
Da Swami's Avatar
You put it in the overflow it cycles through around about when the car reaches operating temperature, you put it in the radiator it cycles through immediately.
In your case it didn't matter. If you are REALLY low, it's generally better to fill straight at the radiator.
At least that's what I was taught.
Old 01-03-2007, 09:19 PM
fortmyerspolice's Avatar
You shouldnt really put regular water, better to put distilled. I heard over time it could cause a build up of crap in the radiator
Old 01-03-2007, 09:37 PM
TXZ28LS1's Avatar
well i used drinking water!! was that good? it was only 1 regular size bottled water? are u also supposed to put water in the raditator also or just the overflow? lol..see its these questions that bug me out..hahaha. but i did use the dex cool for sure.
