Alternator change write-up?
Has anyone done a tech write-up on changing the alt. on the F-body? I have looked and it seems straight forward and not too difficult (but at times I am not too bright). Any help would be great! Thanks!
Its easy, the most difficult part is disconnecting the little red wire connector on the top of the alternator.
Basically all you do is unbolt like 3 or 4 bolts, disconnect the electrical connector, and dissconnect the big red power wire. It takes like 30 minutes to do.
