clutch fluid question
Old 01-03-2007, 11:12 AM
LS198Z28's Avatar
Default clutch fluid question
SO i flushed out my brake fluid last year and it is black again and is in need of bleeding.......bad. Anybody consider flushing thier dot 3 for some dot 5 fluid? if so how do you do it?
Old 01-03-2007, 11:21 AM
steveo346's Avatar
Wow My Clutch Fluid Is Black Also...has Been Since I Bought The Car...i Thought It Was Supposed To Be That Way...should I Change Mine Also..dont Mean To Threadjack
Old 01-03-2007, 11:28 AM
Kleeborp the Moderator™
MeentSS02's Avatar
DOT 3 and DOT 5 fluid are not compatible...I think you'd have to go with DOT 5.1. Personally, I run a DOT 4 fluid (Ate Super Blue) that is working well for me.
Old 01-03-2007, 11:29 AM
MeentSS02's Avatar
I'd change it if it were my car, but that is pretty common for the hydraulic systems on our cars.
Old 01-03-2007, 12:53 PM
LS198Z28's Avatar
yes i know this, i have heard that you can flush it out using brake cleaner, any other tips, or am i going to try this myself?????
Old 01-03-2007, 01:00 PM
SSpeedracer's Avatar
Dont use brake cleaner unless you intend to leave the entire system open for evaporation. Just flush with dot 3/4 brake fluid. You may want to clean out the resevoir and bladder while your at it.
Old 01-03-2007, 04:44 PM
MeentSS02's Avatar
I wouldn't use brake cleaner either...that ****'s pretty caustic.
Old 01-03-2007, 09:13 PM
BLKWS.6's Avatar
I am partial to the "turkey baster" method. Suck clutch fluid out as much as possible, re-fill to full, drive around the block, repeat until it looks clear. Takes a while and uses a good bit of fluid, but if you dont want to bleed it, its a pretty good alternative, if not ghetto.
Old 01-04-2007, 09:32 AM
LS198Z28's Avatar
yeah but i have to bleed it anyway.
Old 01-04-2007, 08:19 PM
kookamunga's Avatar
I second the ATE stuff. I've also used Motul 5.1 and RBF600 but that's usually as a result of eftover fluid from flushing the brakes out
Old 01-05-2007, 11:34 PM
smp777's Avatar
Thumbs up
I agree dont use brake cleaner!!! Spend 50 bucks and buy a power bleeder it will force all the black crap out and its so easy to do and you are bleeding it at the same time. Killing two birds with one stone!!!! I love mine. fluid gets a little black put the power bleeder on it and crack the bleed port let it flow till its clear takes 5 minutes.
Old 01-07-2007, 02:49 AM
crazyed71's Avatar
How do you connect the power bleeder...
Old 01-07-2007, 09:27 PM
MeentSS02's Avatar
If you have the right adapter, it screws right on to the reservoir...just pump it up, crack the bleeder, and it bleeds itself
Quick Reply: clutch fluid question
