looking for a cam ....
Old 01-03-2007, 11:55 PM
z28_n_tx's Avatar
Default looking for a cam ....
ok i searched and search isnt working.....well im seriously thinking about putting a cam in my car by the end of this yr...well first off i was thinking cam only...but is it reliable or will i need heads as well???? i know theres a bunch of cam only cars on here ive seen threads beafore....my current mods are on my sig...if i was goign to go with the cam only which will be best??? i know thats a long shot but my car gets about 50 -60 miles a week..i want it to be streetable....and reliableas well...will i need a stall?? sorry guys fo rthe questions but im a newb when it comes to internals...
thanks
Old 01-04-2007, 01:27 AM
macca33's Avatar
G'day there mate. I drove a Holden Commodore (LS1) with a Comp 222/224@112lsa cam and 3600 stall the other day and all I can say is woohoo!
It is a seriously quick package and has all the manners needed for the street. (MY preference would be for a 2800-3000 stall, but that would be the only change I'd make to it.)
The Commodores over here weigh in at around 1700kg+ and I have no doubt that a low 12-second or high 11 is on the cards for this car. It maintains at least 28mpg on lean cruise (60 - 70mph) on the highway.
Good luck with your choice.
Macca
Old 01-04-2007, 02:52 AM
mvvette97's Avatar
if you stay at a 224 or below your factory stall will be fine. Anything bigger you will want a bigger stall. Honestly if you want good reliability i would not go with the xer lobes. Many people run them with no problems but in fact they are harder on the valvetrain than the regular lobe.
Old 01-04-2007, 08:55 AM
Rede's Avatar
If you're going to hit the track once in a while, or do a little street racing, you'll want a stall.
How high to go is upto you.
I bought a 3200 vig and I'm itching to get it installed!
Old 01-04-2007, 10:14 AM
z28_n_tx's Avatar
can you explain what you mean y xer lobes??? like mentioned above im pretty new to internals....
i keep hearing ppl use a tr224 cam....
keep in mind that i want to keep my stock heads...
also i my car has not seen the track...since ive owned it..but i do get into qa street race evryonce ina while...
i had my car tuned a few wks ago and i talked to the guy at the shop about cam only.. didnt really get in to details as far as what cam but he quoted me around $1,500 or so for cam and labor...
i wanted to get all the info down so that i can save some cash and hope fully get it done either summer or fall of this yr.
Old 01-04-2007, 10:22 AM
onebadrubi's Avatar
They are tamer at idle but more aggressive when climbing the rpms. More aggressive ramp rates.
Old 01-04-2007, 12:19 PM
mvvette97's Avatar
you say that they are tamer at idle, how can they be tamer at idle? just wondering.
Old 01-04-2007, 12:20 PM
mvvette97's Avatar
I believe most of the thunderracing cams are XER lobes
Old 01-04-2007, 01:13 PM
onebadrubi's Avatar
Isnt the ramp rate "smoother" under say 2000-2500rpms then a non xer lobes and then become more aggressive over 2500-3000rpms?
Old 01-04-2007, 04:05 PM
mvvette97's Avatar
intersting. I would like to know more about that
Old 01-04-2007, 05:01 PM
onebadrubi's Avatar
I thought that was the point of the XER lobes?
