Torque arm Bushing
Torque arm Bushing
Again summit ships me the wrong part. >: (
what poly torque arm bushing, do you gus have, if any?
my part # was: ENS-3-1111R
http://store.summitracing.com/egnsea...=KeywordSearch
how much should this run for?
I feel like I was ripped off....
I was charged 206 bucks today for
parts:
-Oil filter
-5.5 qt mobil 1 synthetic
- coolant/antifreeze
labor:
oil change
coolant Drain and refill
power window motor replacement ( I bought the part somehwere else , excluded from charge )
parts:
-Oil filter
labor:
oil change
Originally Posted by SSTYCOON
well if you would have done it yourself... you probably would have saved around a 100$
40$ for oil&fiter
40$ for window motor....not hard to replace.
15-20$ for coolant
40$ for oil&fiter
15-20$ for coolant
I know. I didnt have the time or tools to. Well actually I did have the tools for these services specifically, but I dont for other services that I will soon.
Anyways I had the window motor already.
Kleeborp the Moderator™
Did you get the torque arm bushing figured out? You have to drill out 4 total rivets that hold the rubber pieces in the stock clamshell...2 on each side. The rubber is bonded to some small pieces of metal, and the rivets hold the metal in place. With those out of the way, the mount will fit with no issues. As for the labor...it was probably about right for the time involved to do all of that. Window motors, if you haven't done them before or in a while, take a little while to replace.
