Cloyes Adjustable timing set – Used ok?
Originally Posted by bsf
So, it appears I will need an adjustable timing set since my cam was not ground to my specs. Does anyone see a problem buying a used set? It has less than 2000 street miles and no track passes.
Cloyes makes excellent quality parts. I just pulled a Dbl roller Hex Adj off a Marine 360ci SBC with 800 hours and 12 years useage. It had no stretch at all in the chain. It was as tight as a virgin on prom night!
