Drag Racing Results - ran 13.8 @ 102....where should I be??
arklie
01-05-2007, 11:58 PM
My first and only time to the track I ran 13.8 @ 102 w/ 2.22 60'. Considering my dyno #s, where do you think I should be? If I got some drag radials and a TQ arm could I get a 12.9?
The reason I ask is that a stock LS1 can usually get high 12s with a good 60'. I figure my HP is pretty close to a stock LS1.
What do you guys think??
30th t/a
01-06-2007, 09:42 AM
if you got a stock 10 bolt and your trapping 102 mph with a good 60' I say mid 13's. you need more mph to get a 12.9. you need to be atleast trapping 107 or so with a 1.8 60' and then you'll see your 12.9.
unit213
01-06-2007, 10:40 AM
Who told you that? :confused: High 12's are pretty rare for a stock
LS1. However, they are definitely possible with a M6 car, a 1.9 60,
and some serious rowing.
You're a long way off from 12.90's. Let's say you pick up some drag
radials and you cut a 1.80 60'. You're still looking at a 13.30 or so.
My suggestion would be to pick up some drag radials and add some
more power. You'll get your 12's. :)
Bryan @ Speed Inc.
01-06-2007, 02:38 PM
you'll need a really good 60' to hit that. e.t.
i don't see a 12.9 with that m6 and 102mph.
kennyxg
01-06-2007, 03:12 PM
If you want to run 12's the weak link is the 7.5 ring and pinion.You have the power you just have to launch hard, save your money get a built rear end slicks and a little suspension 5k launch easily high 12's.
tektrans
01-06-2007, 06:07 PM
102 for an m6 seems a little low, especially for this time of year. Wait... he's got a '96-that's actually not bad. Get that 60' in the 1.8's and your lookin' at 13.3's -13'2s.
Lose some weight (like 300#'s and you'll see 12's) or add some power.
86 IROC
01-09-2007, 05:47 PM
What track do you race at? 102 MPH seems like a slow trap for an M6 with those mods unless you're running at a higher elevation.
bjamick
01-11-2007, 12:48 PM
Hey guys is this is an LT1. I was getting a lil confused LOL This is actually moving pretty well for an LT1 car.
ZFan88
01-11-2007, 01:07 PM
I ran a 13.4 at 104, 2.18 60' with a couple less mods than you in my M6 vert. What elevation are you at?
