Help Engine Assembly ?'s
Which way do the bearing caps go? I'm working with TooTall to rebuild his 6.0. We have a problem assembling the crank and bearings. We put the crank and main bearings together, and the crank would not turn by hand. So, we then started in the middle and added the bearings one by one turning each bearing so that we could spin the crank. Some of the caps are facing one way and some are facing the other. If we put all of the caps the same direction, the crank won't turn. Please check these pictures and tell us if this way will work.
Originally Posted by PREDATOR-Z
No need Jason is 100% correct, 1>4 lip facing back, # 5 facing front.
