How to remove oil filler neck
Old 01-06-2007, 02:57 PM
2002LS1Z's Avatar
Default How to remove oil filler neck
I've noticed that the seal for my engine oil breather is not on good and there is a small amount of oil residue leaking. I ned to remove it, but don't want to damage anything and make thing worse. I need the correct procedure to remove this, so I can fix it.
Old 01-06-2007, 03:53 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I had to remove the whole valve cover to get mine off, but I still ended up breaking it. You'll be able to figure it out once you look at it from underneath the cover.
Old 04-05-2007, 07:48 AM
knightdd's Avatar
So the only way to remove the filler neck is to take off the valve cover?
Old 04-05-2007, 08:16 AM
MeentSS02's Avatar
For me that was the EASIEST way...plus I didn't want an errant piece of plastic breaking off and getting into my oil passages.
Old 04-05-2007, 09:08 AM
knightdd's Avatar
The O-ring on my filler neck had come up from between the neck and the valve cover. I just worked it back into place with a screwdriver.
Quick Reply: How to remove oil filler neck
