what rod length for 4.8 crank + ls2
Old 01-06-2007, 04:30 PM
cablebandit's Avatar
Default what rod length for 4.8 crank + ls2
i dont understand all the numbers
stock 4.8 crank in a ls2 block....4.03 pistons
are deck heights different between the 4.8 to ls2 blocks and does this matter?
Old 01-06-2007, 10:10 PM
tuff question i guess
Old 12-01-2007, 06:50 PM
LS1LT1CAM's Avatar
Deck Height Are The Same
But The Crankshaft Is Only 3.28 Inch Stroke
Where As A Ls2 Has A 3.62 Stroke
THE STOCK 4.8 ROD IS 6.400
6.0 = 3.625 STROKE 6.125 ROD AND 4.00 BORE
5.3 = 3.625 STROKE 6.125 ROD AND 3.77 BORE
4.8 = 3.28 STROKE 6.400 ROD AND 3.77 BORE
Old 12-01-2007, 08:33 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Off the top of my head I think it is 6.300. You can use the deck height formula to figure it out, but I don't know if it's going to be exact. If you told me what pistons you were going to be using I could figure it out for you as I need the compression height. Right now I'm just assuming you're using one for a 4 inch stroke. It's still going to be a little rough.
stroke / 2 + rod length + compression height - deck height = amount piston is in or out of the hole.
You want rod length so that changes the equation to:
rod length = deck height - compression height - one half of stroke.
x = 9.24 (variable that makes this semi innacurate) - 1.125 - 3.270 / 2
x = I get a 6.480 rod, but.... You could deck the block to use a 6.300 rod.
You'd also have to take the decked block into account when figuring out the compression ratio also. What do you have planned with this setup?
Here's some additional reading:
https://ls1tech.com/forums/showthrea...ght=rod+length
https://ls1tech.com/forums/showthrea...t=6.0+long+rod
Old 12-01-2007, 10:37 PM
Pyrotechnic's Avatar
Mortec lists this for the 4.8 -
293 = 3.779" x 3.27" ('99-later, Gen.III, "LR4" 4.8 Liter Vortec, 6.278" rod)
Is that rod length correct or not ?
Old 12-01-2007, 10:57 PM
LSXS10's Avatar
What are you tryin to do??? Destoker??
Old 12-02-2007, 11:08 AM
DONAIMIAN's Avatar
Id talk to a couple piston companies to see what they can offer you. I know eagle makes a 6.200 rod tho.
Old 12-02-2007, 12:14 PM
PREDATOR-Z's Avatar
You first have to tell which pistons you are using with pin height used.
Quick Reply: what rod length for 4.8 crank + ls2
