What SCR / DCR to target for?
Old 01-06-2007, 09:33 PM
Marc '99T/A's Avatar
Question What SCR / DCR to target for?
I've been playing with the VE calculator that pianoprodigy tweaked. What is the optimal SCR & DCR that one should target for when running on 92-93 octane with a stock block? I've ordered my cam and am saving up for the AFR 205's. I'm trying to figure out how much, if any, to have them milled when I order them.
Old 01-06-2007, 10:58 PM
The Sad's Avatar
I have read that for pump gas you want your DCR around 8.5:1
Old 01-06-2007, 11:45 PM
pdd
pdd's Avatar
im goin 11.3scr 8.64dcr
Old 01-06-2007, 11:54 PM
ArcticZ28's Avatar
I would play it safe with 8.4-8.5 max.
Old 01-06-2007, 11:57 PM
SLO C5's Avatar
Default Scr/dcr
I've found that 11.0:1 for SCR and DCR 8.3-8.5 for 91 gas is the max you should go. So I'd imagine you'd be a little higher.
Old 01-07-2007, 04:15 AM
PREDATOR-Z's Avatar
I'm running 11.88 SCR and 8.68 DCR on 94 Octane (US grade).
Also keep in mind that as SCR goes up colder plugs should be used.
Old 01-07-2007, 04:17 AM
bad95killer's Avatar
peace
Old 01-07-2007, 11:25 AM
slow trap's Avatar
when i was h/c on the stock bottom i had around 9.0 dcr on 93 octane and had zero issues but that was in the spring time also and with a head that had a slightly lazier runner than an afr 205.i would shoot for 8.7- 8.8 dcr with a set of tr6s or similar.you can always back the timing down a few degrees if you have alittle spark knock.
Old 01-07-2007, 12:56 PM
Ksett's Avatar
Just worry about DCR and let the SCR come out to whatever DCR you choose.
I run 8.7 DCR with 93 octane, you should be fine with 8.5-8.6.
Old 01-07-2007, 01:27 PM
I'm looking at a DCR of either 8.45 or 8.66. At what point should I look at using a cooler plug (like a TR6)?
Old 01-07-2007, 01:29 PM
Ryan02SS's Avatar
8.64-1 here since 2003 with no problems. Daily driver alot of the time. 93 octane with no problems. No knock has ever been monitored while data logging on the dyno or on the street.
Old 01-07-2007, 01:33 PM
The Sad's Avatar
You mention running a colder plug as the ratios get higher. What happens when you through nitrous into the mix? I am already running TR6s for the bottle.
Old 01-07-2007, 01:51 PM
Not sure; I don't plan on spraying.
Old 01-07-2007, 03:00 PM
Ksett's Avatar
I ordered some TR6's for my setup, just haven't installed them yet. I would run the TR6's for your setup as well.
Old 01-07-2007, 09:57 PM
LS1Tech Sponsor
Slowhawk's Avatar
Stock pistons I'd shoot for 8.5-1 or so. We have run 9.2-1 DCR on 10.6-1 SCR before but the compression is pushing it on stock piston/rod combo.
Quick Reply: What SCR / DCR to target for?
