Understanding fittings...
Having some issues here finding the fittings i need to finish my oil drain for turbo set up.... will NPT work with -AN fittings? Like will a 1/2 NPT male screw into a -10an female? Or will an adaptor be required. The part that i am running into issues with is i need to come out of a -10 female OR male drain, into 5/8 hose. the 5/8 hose then has to T together into a 3/8 male pump. So its a lot of converting... if NPT will screw into -AN, then i'm in business. If it does... what sizes mix with which, for example, 1/2 npt screws into -10an ? What -an fits with 3/8 NPT? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
http://www.scirn.net/an_fittings.htm
Have you looked at the usual sites....Earls, XRP etc????
I am having a little difficulty envisioning your setup.
Where is the -10 drain point you refer to?
Which pump are you connecting to?
Does the pump have NPT openings or AN?
Should be an easy solution with all the fittings and adaptors readily available.
im having issues finding what ineed at the normal places. The drain out of the turbos is a -10 male or female, has a little piece in there already that would make it male or else i could take it out and it would be -10an female. So i need a -10 male or female to 5/8 barbed. the drains then need to go to the pump which is 3/8 male NPT so for that i guess i need a T fitting, one end a 3/8 NPT female, and the other 2 at 5/8 barbed.
__________________
I think I am in a similar position as far as trying to get stuff and explain stuff so here's what I did: I got a piece of paper and drew up the system I want to put together with the parts I have and still need. Tomorrow I am going to scan a copy and 1) post it on the board and ask for feedback and 2) after I get it ironed out, send it to someone (like a sponsor) that sells fittings and have them send me what I need. This way, they will know exactly what I am talking about. I labeled all of the fitting sizes and type that I knew so anyone looking at it will have a good idea of exactly what I have and what I need.
Just a thought!
-Dave
Just a thought!
-Dave
ok cool, thanks!
If you are saying that -10an= 10/16, so would a 5/8 male screw into my -10an female? Or would they still not work?
__________________
OK so you have a 10 an coming out of a turbo and need to get to 3/8 basicly, hows this work for you? -10 braided line to a -10 to 3/8 adapter?
these arnt -10 there only -6 but figured it might give you an idea.
but the thing is, i need 2 -10 drain lines going to one 3/8 npt male pump. Heres a list of fittings i need.
2 - -10an male or female to 5/8 barbed
1- T fitting, (1 side- 3/8 npt female, other 2 sides, 5/8 barbed)
1- 3/8 npt female to 3/8 barbed.
It is 2 fittings for oil drain to 5/8 hose, the 2 5/8 hose to T into the 3/8 pump, then 1 fitting for other end of pump to a 3/8 hose, already have 3/8 barbed fitting for the timing cover.
__________________
i only have the oil drain fitting, it connects to my turbo and has a female -10an on it.....?
__________________
AN fittings are 37* flares. NPT is 45*. The AN fittings have zero compatibility with NPT fittings. They will not connect.
The screw in, AN fittings, are a strait thread and use o'rings for sealing.
NPT threads are tapered, and use interference fit to seal.
There are adapters to mate AN and NPT connections.
IE:
3/8NPT male to -6, -8, -10 AN, etc, are common parts.
You can also buy such fittings as strait, 30*, 45*, etc.
FAR too many combos to list.
Do yourself a favor, and get a catalog from Earls, Aeroquip, etc. They will clearly show the combos...
IE:
will NPT work with -AN fittings? Thanks!
k, but my problem is finding a -10 male to 5/8 barbed......
__________________
ok, its over where the car is so i cant get a pic of it. i dont udnerstand why you need to see it though.... i just need a -10an male to 5/8 barbed to fit into it?
__________________
well the oil drain fitting doesnt screw into the hole on the turbos, the oil drain is actually square with 2 small holes o nthe side of it that i attach an oil drain fitting by, but the drain fitting is a -10an female. hope this helps
__________________
