tsp 5.3 stg 2 heads with tsp 233/239????
Old 01-07-2007, 12:31 PM
mjspeed's Avatar
Default tsp 5.3 stg 2 heads with tsp 233/239????
will i run into ptv clearance problems with this combo, and what lsa do you guys reccomend, any videos would help, and also what head gaskets should i use for this combo, will stock gm head gaskets be fine? i am in iraq right now so im trying to get all my parts ordered so i can build my ss when i get home
thank you
Old 01-07-2007, 01:36 PM
The Sad's Avatar
When I ordered my 5.3 heads for TSP, I asked about PTV clearance. He said you could run up to the MS3 with these heads and stock gasket. I was looking at that cam, and it will be fine. (this is making gasket assumptions). Your best bet would be call them and ask.
Old 01-07-2007, 05:59 PM
white_camaro's Avatar
use stock gaskets and id shoot for an lsa of around 112 since your a m6. but i second the sad in giving texas speed a call.
Old 01-07-2007, 06:01 PM
crazylane's Avatar
I am going with this same setup, I called them on friday, and they said it will clear fine. I also asked them if I use Cometic head gaskets, and he said he think it might but would look into it for me. Just call them and they will put you in the right deriction
Lane
Old 01-07-2007, 06:58 PM
bigdsz's Avatar
If your valves are 2.02 or bigger i would not do it without flucutting. I had to flycut with 5.3 heads and a Comp xer 228/230.
Old 01-07-2007, 10:28 PM
mjspeed's Avatar
lets say i end up having to flycut, do they make a tool for this or what is the easiest way to go about it?
Old 01-07-2007, 10:37 PM
brad8266's Avatar
there is a tool for it.
Old 01-07-2007, 10:43 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Jon told me that 5.3 heads with the 2.02 valves and a MS3 you don't have to flycut. He recommended I go with the 2.02 valves because I'm gonna spray. Yes they make a tool to flycut the pistons. Like everyone has said just call TSP and ask them
Old 01-07-2007, 11:12 PM
bigdsz's Avatar
I had to flycut with unmilled 5.3L heads, Comp XER 228/230. I only had .045 clearance for P/V.
