Those who have torn down their own tranny...
I'm rebuilding my tranny as I type this out and I've gotten stuck. I'm trying to slide off the main case from the lower part, but can't seem to get it off all the way. I've taken off the alignment bolts, all 11 bolts on the outer part and the other stuff that holds it to the bottom piece. When I lift the case up, the mainshaft shiftrail seems to be attached to the case because it comes up with the case. This doesn't allow me to lift the case more than 1" because the shift forks hit the 1/2 and 3/4 gears. Anyone have an idea of where I can go from here? HELP!
Did you take out the 2 gold shift rail bolts? They are torx head bolts.
Tremec does have a free service manual you can download
http://www.ttcautomotive.com/English/products/T-56.asp
Yes, I took out the two torx bolts (they were referred to as alignment bolts in the instructions I'm following). I found the problem, it ended up being a roll pin I didn't punch out (holds part of the shift pattern piece to the shiftrail). Thanks for the help.
Originally Posted by Phlip00WS6
Let me know how it goes.. im starting on mine tomorrow.
All is done now though, I just need to get everything back together. I'm going to use a long hollow pipe to "press" the 3/4, 1/2 & 5/6 back on. Good luck on your rebuild.
