do i need a bung for my oil return in the pan?
Old 01-07-2007, 06:17 PM
2002/Black/SS's Avatar
Default do i need a bung for my oil return in the pan?
i just took off my oilpan, what a pain in the ***, even with the k-member dropped alot it still didnt want to come out. well now i can either drill and tap it right now or wait till tom to have someone weld an aluminum bung into the side. do i need to weld in the weld in this bung or will i be fine just drill and taping it?
Old 01-07-2007, 07:20 PM
frcefed98's Avatar
Drilled and tapped mine off the car, doesn't leak at all.
J
Old 01-07-2007, 07:27 PM
otherwhitemeat's Avatar
Same As Above
Old 01-07-2007, 07:29 PM
smokinHawk's Avatar
welded a fitting to mine, id say if you can weld a bung there, your probably thank yourself later.
Old 01-07-2007, 07:35 PM
ABeasst's Avatar
welded bung here. so I can put in any fitting
Old 01-07-2007, 09:55 PM
Turbo LS1 SS's Avatar
bung.....give yourself a strong seal
Old 01-07-2007, 11:05 PM
anarchy99's Avatar
If you have the option, I'd weld it for the piece of mind. On mine, the fitting was in the front of the pan and it stripped itself loose from tension on the oil return line. Could have been nasty if I didn't catch it in time. Thought the damn car was on fire. Went back and got it welded in if nothing else just for the piece of mind.
Old 01-07-2007, 11:51 PM
im gonna weld it tom and post up some pics
Old 01-08-2007, 04:30 AM
EPP
EPP's Avatar
Smile
Here is where we welded in a bung for the oil return line. Bob
Quick Reply: do i need a bung for my oil return in the pan?
