will LS2 lifter trays fit an LS1?
Old 01-07-2007, 10:06 PM
mvvette97's Avatar
Default will LS2 lifter trays fit an LS1?
Some say yes and some say no. Who has used them?
Old 01-07-2007, 10:07 PM
Screamin_Z's Avatar
what's the difference in the 2?
Old 01-07-2007, 10:10 PM
mvvette97's Avatar
well I don't know. I was told the LS2 are better so that is what I was going to buy. Just not sure if they will work or not
Old 01-07-2007, 10:50 PM
sandragnx's Avatar
04 ls1s come with the ls2 style lifter trays.I just did a head and cam swap on a 04 ls1 crate engine and the trays that were in there were the same as the ls2s.Also noticed 04 ls1 blocks use the short head bolts/studs like the ls2s.
Old 01-08-2007, 05:10 AM
vettenuts's Avatar
I looked at both when I did mine, there is no advantage from what I can see as far as them being better. I went with the LS1 lifter trays.
If you do change them, check the bottom of the installed trays for any marked "10". There were some issues with the "10" trays. I found one in my car.
Old 01-08-2007, 07:06 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
tray is a tray. What is wrong with a stock LS1 tray?
Old 01-08-2007, 08:18 AM
427's Avatar
LS2 tray will work in all engines, LS1 tray will not work in LS2. I have not seen that one is better than the other.
The difference is for assembly line, to make sure the cylinder de-activate lifters get put in the right place.
Kurt
